FIAT Auto Specialist Team
Old 15-05-2019   #1
Control system on steering wheel
I had problems with the horn not working through 360 degrees of turning the wheel, the fault was in the mechanism behind the boss / airbag. Needless to say this is all plastic and upon examining it with my fingers it sprang apart, I think I got it back together again apart from one plastic cog which where it goes heavens knows, anyway I put a new steering wheel and boss on the car connected the battery and went to start the car which I did (surprised) as I need to put a starter motor on the car as well once I can fathom out the bolt size, I digress after starting the car the instrument screen goes haywire and says airbag malfunction and a load of gobble goo that I can't say what also the radio control don't work, well none of the buttons on the wheel work, as I know nothing of car electric or car ecu can anyone give some advice other than scrap this 2008 fiat Grande Punto
malcolm111 is offline Reply With Quote Quote
Old 15-05-2019   #2
Re: Control system on steering wheel
You haven't connected the cables correctly or the clock spring is broken.
SRafferty is offline Reply With Quote Quote
Old 16-05-2019   #3
Quote Originally Posted by SRafferty View Post
The cables can only be connected one way and not interchangeable, what clock spring?
Old 16-05-2019   #4
It's the cable inside the plastic hub around the steering column just behind the steering wheel. The indicator and wiper stalks are connected to it. The wires inside the cable can work harden and fail over years of turning the steering wheel. Not too difficult to replace. You should be able to pick one up on eBay. OE expensive.
Old 16-05-2019   #5
Old 16-05-2019   #6
I will try and replace it f I can get one with cruise control , thanks
Old 16-05-2019   #7
Quote Originally Posted by malcolm111 View Post
I'd be surprised if it's different from the one in the 500 / Tipo etc. So if you can pick one of those up more readily you could try it. Just make sure who ever you get it from will accept a return before you buy.
Old 16-05-2019   #8
I'm just waiting for a reply from a fiat dealer how much they are
Old 16-05-2019   #9
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Punto controls are GM family, rather than FIAT family, so they will be different. However that still leaves the MiTo and the ubiquitous Corsa to raid parts from.
Eklipze3k is offline Reply With Quote Quote
Old 16-05-2019   #10
The stalks are the same design though, aren't they. Anyhow I could be wrong.
Old 16-05-2019   #11
No strings on me
Eklipze3k's Avatar
No, very different to "pure" FIATs of the same era. My ex had 2 Grande's, I've got a MiTo currently and have owned various other Puntos, my wife has a 500. The 500 shares the same stalks that the old Punto Mk2b had.
Thanks SRafferty thanked for this post
Old 16-05-2019   #12
Quote Originally Posted by Eklipze3k View Post
Good to know. Thanks
Old 17-05-2019   #13
Ordered one from fiat they are £114 which being the first major expense on the car in 10 years, so itís cheap motoring, it has to come from Italy itís not a stock item
Old 18-05-2019   #14
Belgium
Hi Malcolm, have you ordered the cruise control version ?
BRs, Bernie
Old 18-05-2019   #15
Hopefully you’re not using the car at the moment, the risk of the airbag now being incorrectly wired in seems high and in the wrong situation depending on how it’s now wired could deploy.
I’d take it apart again till the new piece turns up or at least disconnect the car batter.
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
(T) Steering wheel control help wellbeloved747 Grande Punto 1 16-02-2015 13:46
Please Help!!! Steering wheel control problems Mrjonnydz Lets Talk FIAT 0 07-01-2012 17:01
(T) problems with steering wheel control sydys Stilo 0 26-07-2010 12:01
Stilo Steering Wheel Control baytunc I.C.E 10 31-12-2008 12:23
(T) Steering Wheel Control Failure!!! fatboyj Grande Punto 9 10-08-2007 19:47
