Thread Tools
Old 14-05-2019   #1
Spark plug ignition lead connections
Hopefully an easy one to answer for those in the know. I'm just wanting to check the order in which the Spark plug ignition leads should be connected on a Fiat Grande Punto 2006 1.4.
Firstly, I presume the left most spark plug connects to the left most plug on the ignition coil pack, the second from the left to the second left most plug on the coil pack and so forth?
Secondly I noticed that two spark plug ignition leads out of the set of four have longer connectors (the wide part at the end that connects to the spark plug), the the other two ignition leads having shorter connectors. Why is this? Does it matter which spark plug the two ignition leads with the longer wide connectors are connected to?
Hope that makes sense!
lmrtw is offline Reply With Quote Quote
Old 15-05-2019   #2
Slovakia
Re: Spark plug ignition lead connections
Its exactly as you say. Eveything :-) What I cannot confirm right now is if cables with "longer connector" are going to sparx 2 and 3 , or 1 and 4. I dont have car here - but on original wires are numbers for each position:
https://youtu.be/0CDr2SDtDbY
Rado77 is offline Reply With Quote Quote
Old 15-05-2019   #3
varesecrazy has donated!
My grandes are different
( 2 HT leads between 10 cylinders.. )
Why do you ask?
Have a running problem.. or about to do some work??
Charlie
Old 15-05-2019   #4
Thanks for the responses and the link to the Youtube video, looking at that video at around 7.00 mins it appears to show the connectors with the longer wide parts in sparks 2 & 3.
I'm still not sure why all the ignitions leads don't have the same connectors to the spark plugs?
Old 15-05-2019   #5
Slovakia
I was surprised too, but maybe because increased heat in the middle of engine...really dont know
Grande Punto (III) 1.4 8V m.y.2013 (350A1000)
Old 16-05-2019   #6
formerly PuntoR60SX
Pickwick's Avatar
Pickwick has donated!
Quote Originally Posted by lmrtw View Post
The picture in Step 3 of this guide with the leads numbered 1 to 4 looks to confirm that
https://www.fiatforum.com/grande-pun...nt-1-4-8v.html
I'm also puzzled by the longer connectors in the middle...
Pickwick is offline Reply With Quote Quote
Old 17-05-2019   #7
Quote Originally Posted by Pickwick View Post
Thanks very much, that image of the spark plugs is excellent and as you say confirms the ordering.
Old 18-05-2019   #8
Belgium
Not to confound with the firing order which is 1-3-4-2 !!
BRs, Bernie
Thread Tools
(T) spark plug and ht lead guide please leroya500 Panda (2012+) 3 10-08-2016 18:50
Spark plug lead clips to tart up your engine bay Adrian Bravo Auction Watch 2 06-06-2009 18:17
(T) HT lead connections......HELP username Punto (Mk2/2b) 10 01-05-2004 05:53
(T) HT lead connections......HELP username Punto (Mk2/2b) 2 01-05-2004 05:37
