Hopefully an easy one to answer for those in the know. I'm just wanting to check the order in which the Spark plug ignition leads should be connected on a Fiat Grande Punto 2006 1.4.
Firstly, I presume the left most spark plug connects to the left most plug on the ignition coil pack, the second from the left to the second left most plug on the coil pack and so forth?
Secondly I noticed that two spark plug ignition leads out of the set of four have longer connectors (the wide part at the end that connects to the spark plug), the the other two ignition leads having shorter connectors. Why is this? Does it matter which spark plug the two ignition leads with the longer wide connectors are connected to?
Hope that makes sense!
