Thread Tools
Old 09-05-2019   #1
Australia
Steering wheel controls not working
Hi
As the title states,
Steering wheel controls stopped working all of a sudden the other day,
Also have the airbag failure message and horn not working too,
Can anyone tell me the location of the connections
llamallama is offline Reply With Quote Quote
Old 09-05-2019   #2
Re: Steering wheel controls not working
Possibly what's called the clock spring behind the steering wheel.
SRafferty is offline Reply With Quote Quote
Old 09-05-2019   #3
You need to remove the wheel to get to it.
Old 09-05-2019   #4
Australia
Ugh, that's gonna be a pain,
I'll check it out on the weekend,
Cheers mate
Old 09-05-2019   #5
Quote Originally Posted by llamallama View Post
Cheers mate
ELearn is worth downloading if you haven't already done so. You'll find it on this site. It's a full fiat service manual. Very useful.
Old 09-05-2019   #6
Australia
Yep
I have it,
Old 10-05-2019   #7
Belgium
Cheers mate
well, not really if you know the tricks...
- disconnect battery (earth is enough)
- insert ignition key (to free steering wheel lock)
- adjust the wheel down and toward you (if applicable)
- position the wheel @ 3 o'clock
- behind it, in the left (now on top) branch you'll find a hole
- insert a flat 2-2,5mm screwdriver and pry the spring located in the hole while pulling the airbag/horn
- once the clip is released from the spring, the airbag will slightly pop-off
- position the wheel @ 9 o-clock
- release the second clip
- return the wheel to 0
- earth yourself to ground (ESD wrist is a good idea)
- remove and disconnect the airbag, store it in a safe place
- disconnect other connector(s)
- remove the central locking nut or screw
- remove the wheel
The main difficulty is to "feel" the locking spring. Unfortunately I don't have any picture of it from inside but I'm sure you'll manage their release!
BRs, Bernie
Thanks llamallama thanked for this post
Likes SRafferty, varesecrazy, llamallama liked this post
Old 10-05-2019   #8
Australia
Excellent
Thanks for the run down
Old 11-05-2019   #9
TigerTom has donated!
I found a hex key easier than a screwdriver to get the clips to pop.
Fiddly if you haven't done it before. Good luck.
Likes llamallama, varesecrazy liked this post
TigerTom is offline Reply With Quote Quote
Old 12-05-2019   #10
Australia
No worries
Old 12-05-2019   #11
flisko has donated!
when you will get another stalk be sure its close to center or else you will break the wire inside
Thanks Bernievarian thanked for this post
Likes Bernievarian liked this post
flisko is offline Reply With Quote Quote
Old 12-05-2019   #12
Belgium
Quote Originally Posted by flisko View Post
when you will get another stalk be sure it's close to center or else you will break the wire inside
One of the steps says "return the wheel to 0" ...
I believe a new clock-spring or stalk assy will come with a lock-pin that needs to be removed during installation.
BRs, Bernie
Thread Tools
(G) Steering Wheel Controls Not Working (Only one side!) AntivirusAbdo Grande Punto 2 15-08-2017 18:10
(T) Steering Wheel Controls not working darkdrifter10 Grande Punto 3 10-02-2017 17:31
(T) Steering Wheel Controls Not Working intel131 500 29 05-10-2016 22:36
(T) Steering wheel controls not working Gabie30 Sedici 4 28-04-2015 17:41
(T) Abarth - steering wheel controls not working! embee427 Stilo 1 24-01-2010 23:56
