Well, the 8 studs for the manifold arrived, but still waiting for the drill bit + extractor. The studs look correct (well, they should be since the part number matches
But meanwhile, I noticed that the head gasket appears to be leaking. Not sure if they are all related, but if the cylinder cover is warped, it's beyond me and my equipment. It would probably be an expensive repair at around 1000 EUR (1100 USD), which is quite close to the actual value of the car itself
But let's see what the service says. If it's more than 1000 EUR, then I guess I'll just sell the car for parts and get something else. It's a shame, as the car is otherwise in good condition (passed the inspection just a few months ago) and it's a fun car.
Here's the full chain of events btw:
1. Brought the car for the yearly inspection, where it failed due to emissions (they measure it from the exhaust pipe)
2. Following a tip, I filled it with a 40/60 mixture of E85 (ethanol fuel) / regular 95 RON, and then I drove around for about 25 mins at around 4000 rpm +/- something.
3. The car passed the inspection with mostly 0 emissions, with occasional spikes at just below max passing emissions. After the inspection, I filled the car with normal 95 RON fuel to max.
4. But after that, the car smelled quite bad for a week, but then it started to get back to normal.
5. However, there still remained a lingering bad smell in both the exhaust fumes and also under the hood.
6. I noticed that the pre-cat oxygen sensor was actually smoking from around the hole even when idling, even though it was tightened to spec. I then thought it's just some WD-40 residue burning off, which I applied a day before the next step on the studs and the exhaust pipe bolts.
7. So then I washed the catalytic converter (this thread), and used new gaskets for the manifold and the exhaust pipe side, plus applied new copper paste on the pre and post cat oxygen sensors. That's when the stud snapped, but it didn't show any signs of leaking, flames or odd behaviour.
8. After that, the car still worked well (the oil temperature never rose above nominal), but still smelled quite bad. I didn't see any oil near the cylinder cover.
9. Then after driving for a week or so, I checked how it looked and then I noticed the area just below the cylinder cover having a little bit of oil across the length. Kind of odd, because I never touched that part - just the manifold that is much lower.
10. That's when I stopped driving it, and now I have the service booked for Friday.
