Technical Need some help ASAP
BJHaig
Hi Guys,
I was driving normally yesterday put my foot down a little bit only about 60% throttle, Suddenly the car went into limp mode and wouldn’t go about 45-50? When in any gears above 3rd the car feels like it’s going to stall. There is a big hissing noise coming from the bottom of the engine and when I put my foot down a big cloud of black smoke comes out the exhaust. There is no boost what so ever. Anyone have any idea? Is this the turbo blown or a boost pipe blown off?
Could the turbo pipes be leak? Or the turbo itself? - years ago I had same with my punto. The waterpomp broke Down. I was on highway and I stepped on gas and I saw the meter of speed dropping down. I had to pull over no gas anymore. Then was waterpump. My cruise control didn't work, at the dealer they say it is protection because something G in the pipes of turbo or turbo itself is leak
Most probably the pressure pipe has blown or got disconnected somehow. What engine is that ??
BRs, Bernie
Most probably the pressure pipe has blown or got disconnected somehow. What engine is that ??...
I second this. Open the hood and check for loose air piping/hoses.
