Looking for some help with a 2008 1.2 8v Grande Punto. Just rescued the car from going to a scrapyard for non starting issues.
So i turn the key, car turns over but doesn't want to start. checked for spark and getting that fine. if i turn ignition key on and off a few times to let pump run, the car will then start and runs for 2-3 seconds and then cuts out. doesn't seem to respond to throttle. try and start it again and just turns over. prime it 2 or 3 times and it will start and cut out again. Also starts after squirting some easy start into intake. I haven't tested actual fuel pressure yet, although the rail is pressurised.
the previous owner had a garage replace starter motor and battery. and subsequently and auto electrician who has apparently confirmed the loom is fine after repairing a connection between the ecu and fuse box. it still wouldnt start and he thought it was a accelerator pedal issue, so its had a new pedal fitted but still no joy. Owner gave up on it at this point.
I have found a few similar topics on here, but a few havent been updated with what the actual fix was. If anyone has any suggestions it would be appreciated.
