Bernievarian
Prominent member
- Jan 15, 2017
- 2,993
- 654
The "little oil can symbol light" is connected to a pres... (shortened version ;-)!
Agree 100% with Jock !
The best car owner's friend is cleanliness... HAND-clean your car once a week or at least every fortnight, don't miss the inner edges (bonnet, hatch, doors) nor the wheel arches (dampers can leak), it'll take only a few minutes more if done regularly. While the bonnet is open inspect the engine for any leak and wipe/blast the dust or debris (leaves) that might accumulate in the corners.
The engine having been at rest while you pampered the body, it'd be the ideal moment to check the oil and coolant levels ... and top them if necessary. Brake and clutch (if hydraulic) fluid level WILL vary with wear, don't top them !! Finally fill-up the screen washer fluid and you won't be surprised by an empty reservoir and dirty windscreen ...
BRs, Bernie
