Thread Tools
Old 04-03-2019   #1
Denmark
Window washer stalk
Hej guys. New to forum. Just got my second GP and have an issue with the window wiper stalk. It does not clean the window when you lift the stalk up for one time clean. When you turn the other functions, it works, even the back window function. What could be the issue? dead contact?
Ade911 is offline Reply With Quote Quote
Old 05-03-2019   #2
nikrox has donated!
Re: Window washer stalk
TBH I have no real answer for you ...BUT I have an intermitent fault with the indicater stalk,when its cold it sometimes works,sometimes doesnt ...its a common fault.
Remedy..air bag off and replacement complete unit.
nikrox is offline Reply With Quote Quote
Old 05-03-2019   #3
Belgium
The way the stalk work is by using different combination of resistors to provide the different voltages to the BCM, which will undestand what command driver wishes to execute. Bad contact or bad internal resistor for this 'one click cleaning' and the fonction will not work ...
BRs, Bernie
Old 07-03-2019   #4
flisko has donated!
Quote Originally Posted by Bernievarian View Post
BRs, Bernie
wise papa smurf
flisko is offline Reply With Quote Quote
Thread Tools
(G) window washer msi64 Bravo / Brava 7 22-01-2009 20:18
(T) window washer help nmt60 Punto (Mk2/2b) 13 18-05-2006 00:47
Headlight / window wiper stalk help bigDAN FIAT Boo Archives 1 16-04-2006 15:52
