Providing the engine mounts are in good shape, probably not depends whether or not you'll need to be directly underneath it.
Not under my car just now but I'd most likely go in this order.
Tie calipers to springs, remove lower strut bolts from hubs after splitting track rod ends from hubs. Remove inner drive shaft boots and then remove lower arms with hubs and drive shafts attached. With be heavy but quickest way. Exhaust will also need to come off or be dropped at the least.
Not looked at removing the rack but likely be splined shaft similar to wiper arm if it needs to come off still attached to the subframe. Once you've sussed that bit, it should be a case of unbolting from body and removing gearbox mount to remove subframe.
I've changed gearbox mounts on my cars and if I was going to be working under the engine with this removed I'd support engine using a bottle Jack and thicj plywood under sump.
If nothing is too stuck or breaks, it should be doable in a weekend at home.
Ben
