- Apr 9, 2018
- 34
- 9
Hi Guys,
I have 2006 GP 1.4 8v, 5 door and suddenly my driver side (RHD) power window stopped working.
at first I noticed the automatic mode was not functioning properly and then after sometime the window stopped working time to time.
when i open and close the door it worked and stays for few days and now completely stopped.
I checked the fuse in the engine compartment and it is good. didn't check the boot fuse box as it's for rear windows.
Also i have replaced(one at a time) and checked both window switch panel and the regulator motor with a working parts (my friends car) and it was the same. So i assumed the issue is with wiring.
Then I removed the rubber grommet between the door jam and door and checked for damaged wires and couldn't find any. didn't check thoroughly by end to end by wire though.
Is there any way to check pin to pin connectivity and test both switch and the motor with multi meter?
