Bill Tsouk
- Jan 20, 2019
- 7
- 1
Hello guy's.
I am new in community and i think my fiat G. P has issue with manifold. When the car is cold and start the engine i have a little play on rpms for example from 1400 to 1300 and also i hear a noise like pull air from some cracked tube... After little time when the rpm falls to normal rpm (850 rpm) the noise stoped and the engine not jerk..... I had replace all coils my sparks is new i had check all inlet from front for any air leak but i cant find something. Also my fuel trims seems ok ( long fuel trim +3%). In running conditions like a trip a havent some issue its all ok only on the morning. Can you help me???
Thank you.
Thank you.
