Thread Tools
Old 04-01-2019   #1
Denmark
Where to get constant 12V for GPS tracker unit?
Hi forum!
Recently got a little GPS tracker unit. It works with a SIM-card so I just have to make a call to the GPS and it will text me back coordinates or link to Google maps (depending on the setup).
This model is without battery and has to be connected to a constant 12V source to work. With constant I mean a 12V that is always on (as long as the battery is connected).
In case of my car getting stolen I think it would be a bad idea to connect it to these obvious points:
*Ignition (wires might get cut here).
*Radio (if radio is pulled out for easy money they might cut the wires instead of pulling the plug).
*Under the hood (the GPS tracker is waterproof but I would prefer it inside the cabin somewhere.
Of course, withouht a internal battery in the GPS unit, I will have to rely on that those bastards doesn't disconnect the battery. My thoughts are that a GP isn't normally expensive enough for people to think that it might be under GPS surveillance
When I get home later I will start browsing through Haynes electric section - maybe someone has a great idea until then?
MrMogensen, Denmark
Grande Punto 1,4 T-Jet 120HP
MrMogensen is offline Reply With Quote Quote
Old 04-01-2019   #2
Fuse tap in the glovebox and install it underneath the dashboard hidden away? I have a fuse tap for my dash cam so itíll use parking mode (time lapse) when itís parked up, and itís tapped from the interior lights fuse (I have LED lights and there isnít much current draw from the dash cam).
Thanks MrMogensen thanked for this post
Moody Blue is offline Reply With Quote Quote
Old 04-01-2019   #3
Sweden
Re: Where to get constant 12V for GPS tracker unit?
One of the EOBD pins on the connector has constant +12V. Also quite easy to get access to.
Used to own CCS 1.2T, now it's gone
woj is offline Reply With Quote Quote
Old 04-01-2019   #4
Denmark
Quote Originally Posted by Moody Blue View Post
Fuse tap? From the fuses just near glovebox you mean?
Old 04-01-2019   #5
Quote Originally Posted by MrMogensen View Post
Iím a forum newbie so Iím not allowed to add links yet, but if you Google ĎAutoleads Mini Blfe Add-A-Fuse youíll see what I mean.
And yes, pop the cover off the fuse box and this is the fuse youíll be looking for, thatís the one for the interior lights and what Iíve tapped off of for my camera.
Thread Tools
(T) 12v constant supply Nickhmh Panda 11 13-02-2018 20:14
(T) Wiring 12v accessories on constant live? GizmOwin Stilo 11 29-07-2012 15:18
(T) Switch 12V socket to constant power? Atlessa Panda 9 23-02-2012 01:01
12v constant and amp help please daz90 I.C.E 8 02-08-2010 22:09
(T) 12v constant Trist Punto (Mk2/2b) 4 24-05-2009 01:46
