Styling Wheel offset on T-Jet
ThatFadedTjet
Hello, I’m new to the forum. I’m looking at new wheels for my tjet, I got told by a follower on Instagram that regarding wheels I can go up to 8/8.5j width as long as they’re ET35, the wheels I’m looking at are ET25 and 8j. Wondering if these will fit regarding the gap between shocker and wheel, I run spacers on standard wheels as is so can use these to avoid contact if necessary.
Many thanks!
Compared to a 8.5" ET35, the 8" ET25 will be farer from the McPherson leg : 10mm less offset + 0.5" width difference /2, or 10 + 6.35 = 16.35mm and they will protrude more : (-10 - 6.35 = 3.65mm )...
So you can probably get rid of your spacers.
Cheers, Bernie
