Technical Checking oil level before or after journey?
VirtuousGuy
Will be checking my oil levels for the first time (new driver first car) and just wanted to check if the accuracy of the reading will make a difference if checked before a journey or directly a few minutes after completing a journey.
The bottom line obviously is the engine should be cold, but the instructions in the manual explicitly states oil levels be checked a few minutes directly after a journey but i'm wondering if it would make a difference if checked first thing in the morning or even days without use for example?
ENGINE OIL fig. 3-4
Check the oil level a few minutes (about 5) after the engine has stopped, with the car parked on level ground. The oil level should be between the MIN and MAX marks on the dipstick.
@VirtuousGuy
Normally the cold level will be slightly lower than the hot because hot ol expands. As long as it's beween the marks, hot or cold, it will be OK. Level does make a difference. If you normally park off level, even one sides wheels in the gutter, try checking the oil with the car facing both ways to see how much difference it makes.
Robert G8RPI.
