General Heater not working...
BethRafferty18
Hey all!
Was wondering if someone could offer some advice. My heater stopped working on my fiat grande punto 06 plate a couple of weeks ago.
At first it would come on intermittently and now it’s stopped all together.
I’ve replaced the resistor (which turns out it had a plastic bag melted onto it, from previously owner used to keep nappy sacks in the glove-compartment and one had fallen down??*♀️). Once I’d replaced the resistor it still wouldn’t work, checked the pins and cables and all seem fine, no signs of wear or melting. If I gave the fan a bang it would attempt to go but just sounded like a bit of Card was stuck in it.
Which brings me to my next suspicion as to what it could be... I read on another thread about the fan having leaves and debris stuck in it. So I took the fan out today cleaned all the leaves out, but still haven’t had any luck with the fan working at all.
Does anyone have any idea? I’m at a loss and not really enjoying wiping the windshield every 5 seconds to be able to see ??*♀️
Any advice would be great
Thanks guys!
Hi guys, the fan moves by hand, but won’t move once it’s placed back into the car and connected. I’m thinking maybe a duff connection?
Do you know which fuse it is at all Charlie?
You can direct feed the fan's motor with 12VDC from the battery and see if it spins.
Do that with the fan installed, you only have 10 fingers !! Alternatively use an adjustable power supply that you can crank-up the output current until the motor starts spinning .
You can also feed an headlight bulb from the resistor pack and see if it glows. This would give you an indication of who's the culprit.
BRs, Bernie
Hi Beth,
I have an 07 Grande Punto and have had fun and games with the heater fan for years – and had never had a problem with those of other (non Fiat) cars I’ve owned. I don't know whether your car is similar in its electrical design/equipment to mine, but my problems - and their resolution - might help you solve yours.
1) Resistor block failure
My fan's 4 speed switch governs fan speed via a ceramic-encased block of in-line resistors that looks like a pale green ice lolly without a stick. This weird thing is mounted in one of the plastic airways leading to the fan – presumably so that incoming air keeps it cool. On my car it’s under the dashboard on the passenger side, and you need to be a limbo dancer to get to it. Find a multi-plug with six or so cables entering it and you’ve got it. The block’s held in place by a single, tiny screw – male hex head, I think, about 5mm/5.5mm AF.
At position 4 these resistors are bypassed (i.e. there’s no resistor, in effect), so the fan gets 12V (or whatever the alternator is putting out). (Have a look at the circuit diagram someone posted and you’ll see what I mean.) At positions 1, 2 & 3 the relevant resistor drops the voltage, and hence the fan speed. Manipulating voltage in such a way (presumably) causes the resistors to heat up - so despite it being cooled by incoming air the resistor block doesn't last more than a few years. What tends to happen is that its coating spalls as one or more of the resistors breaks down. Since position 4 doesn’t have a resistor, if the fan works at that setting but not at one of the others, you know what the issue is. I gather some Punto owners just continue to run the fan at the highest speed. Works fine but it’s pretty noisy.
When my fan first stopped working a few years ago I discovered the block so badly burnt out that the path at position 4 had also perished. I replaced the block (£10-odd from Ebay) and the problem was solved. (Had to splice it into the existing wiring using a strip of heavy duty (30A) cable connector block - fiddly due to having to work upside down!)
2) Fan running intermittently and unevenly, and at times not even coming on.
This happened twice last year, and each time it was the same issue. First port of call was of course the resistor block, but although it had started to crumble the fact that some power was getting though suggested that the fault might be with the fan itself.
It turned out to be carbon build-up on the fan rotor commutator – the usually shiny bobbin of copper that the two carbon brushes press against to magnetise the rotor windings. My guess is that it was caused by a combination of overnight condensation of damp air on the brushes/commutator and then running the fan for only a few minutes the following day (or the day after) on a short trip to the shops, etc.
Fan removal/repair procedure is/was as follows;
a) limber up for limbo dancing and find a torch
b) remove the twin cable multiplug from the fan body
c) remove the screw (female Torx head) securing the plastic fairing that directs hot air down into the footwell and tweak the fairing out (it’s fiddly to put back in)
d) remove the three tiny (5.5mm AF?) hex head screws securing the fan, and drop the fan out
e) remove the fan body cover to expose the commutator and brushes. (My cover was held in place by two tiny, rusty and very fragile looking male Torx headed screws which I was therefore loathe to touch – but while it’s visible with the cover on, cleaning the commutator of carbon deposits was soooo much easier with the cover off (and you can check brush life too). As it turned out the feeble Torx screws were into plastic, and loosened quite easily.)
f) hold a bit of emery cloth against the commutator, turn the fan several times by hand, and lo and behold, a nice clean contact surface once more. Blow out the arisings or they’ll shag your fan when you put it back together.
g) put it all back together and the fan should work again. Mine did. :)
h) visit a chiropractor to have them unravel your spine.
3) Fan switched on but not coming on until you thump it or drive over a speed bump
I’ve had this happen too – and haven’t been able to find the cause. Checked all the cables, multiplugs, etc., but all seems well. That said, I’ve noticed that after cleaning the commutator this problem disappears for a while too, so I’m guessing it’s to do with carbon build up and that a quick jolt is enough to get the motor running each time, and that it then self-cleans (in a fashion).
Anyway, hope this helps you – and anybody else who has these niggling problems with Fiat heater fans. Last note: when I sourced the resistor block I seem to recall it fitting several models (and even makes) of car – so these faults and fixes may apply to other marques.
Happy New Year all,
Mick
Hi Mick and welcome on the forum...
Very nice introduction indeed ! Precise, exhaustive and well described: you put it at high level !!
Carbon built-up usually lock the brush(es) so the contact with the commutator get so bad that the fan doesn't rotate anymore; probably why slaming the fan body would have curred the issue for a while (3rd symptom)...
Cheers, Bernie
Hi Bernie,
Aha! Brushes stuck to a stationary commutator! That figures - thank you. :)
It's a bugger, when the car usually gives me no grief*, that something as workaday as a heater fan stops me from driving it. Misty windows aren't a good idea.
Best regards,
Mick
* That said, the car's up on ramps since yesterday, awaiting a new gear linkage cable. Left side snapped a couple of days ago, and I was fortunate that it got stuck in 2nd gear instead of reverse! :)
A contributing culprit for failure of the resistor pack that Mick describes is a clogged pollen filter. It restricts the flow of air which is essential for cooling the resistor pack, especially at the lower speed setting (less air flow + higher resistor pack energy to dissipate!) A good reason for changing the pollen filter regularly!
Hi Bernie,
Hey Mick, I meant o-c the brush(es) stuck in the guide and the weak spring not being strong enough to insure a good electrical contact ...
Cheers, Bernie
Hi Bernie,
Ah, I see. Well, still figures. Haha!
The springs were a bit feeble, come to think of it - and the brushes were hard wired in place - unlike those I've renewed in power tools over the years. Guess they didn't expect their fans to be maintained to that degree; but I'm not a fan (no pun intended) of this throwaway society. :)
Best regards,
Mick
The heater on my Punto doesn't seem to produce much heat. The motor fan works fine but the air isn't as warm as I would expect. The engine warms up correctly on the temp gauge which then steadies at the mid-point on its scale. The sytstem isn't leaking.
Is there possibly an air lock on the water pipes to the heater and if so how would I set about clearing it?
Guy
This is a great guide. I was looking for a reason that my heater fan would only work on high yesterday, and now I understand about the resistor being bypassed on high setting it makes sense. However, today it is working perfectly again.
So, maybe the resistor, maybe wiring on its way out.
Will check both, but thanks for the guide, I am sure it will help me get it off!
