Hello,
car is 1.3 multijet 55kw grande punto and it has suffered some codes lately. At first high pressure pump leaked inside motor and mixed oil and diesel. I got it running with cleaning, changin oils and with gaskets changes.
But still with hard acceleration fuel pressure drops with 3-4-5 gears and code p0089 come & limp mode. I have checked graphs with Mes and i'm not sure what readings there should be...with some parameters.
I quess theres some problem with low pressure pump or alternator/electricity.
Alternator gives normal readings on battery - 14,4v while motor running, but mes shows (ecu) reading 13,5v. Ground contact ?
Intake air quantity shows 250-500 mg/i reading while driving and calculated readings are always about 200mg/i higher?
What other readings could tell me more info?
Lambda, map has changed, those are good.
Commonrail regulator seems to work okay, but not yet cleaned.
Pressure goes high with 2 gear.
