Technical Faults error messages
Changed clutch and slave was ok for a few days but now really hard to get in gear and the bite points practically on the floor
Bite point on the floor ?
- air in the circuit: need to bleed it
- worn thrust bearing or clutch spring: need to replace
Try first to bleed, it's the simplest ...
BRs, Bernie
