I have a GP 1.4 8v, the exhaust has been blown for a while, I finally had the time and money to fix it. Decided to replace the whole exhaust including the cat and manifold because I got the parts for fairly cheap and it's relatively easy to do.
We went to remove the manifold and not only noticed that nearly all of the studs were loose, and one was missing. We thought it was a bit odd but carried on otherwise. The bolts were fairly easy to turn, we weren't putting very much force on them at all.
But the bolts kept shearing. One went, then another, then another. 3 bolts sheared... At this point we decided to stop, because we had no way of getting the broken bolts out at that time, and no bolts to replace them with anyway.
We did up the rest of the bolts that are holding it on and that's how it's sat at the moment. We're planning on trying to fix it next weekend, and I don't plan to drive the car much if at all between that time.
I've seen a few posts and a few sources say that the bolt size is m8? It was 10mm when we were doing it. I'm wondering is that the right size for a 1.4? Or has some clueless mechanic put the wrong size bolts in at some point... do I need M8 or M10?
Anyways any help will be greatly appreciated
Thanks.
Thanks.
