Thread Tools
Old 07-11-2018   #1
Help needed MES leads
Having had the day off, I headed to the garage and did battle with the undertray, oil filter and changed the oil in my 1.6 multijet. Even welded a massive nut on the sump plug because the head was showing signs of rounding offClick image for larger version
ID:	195270 even made a spanner to deal with the filter all good and smiles so far but then!!!!!!!!!!
I went inside got the laptop and fired up MES but where are my leads........ fast forward to now the garage has been stripped and put back then the house and nothing having done many more searches I just donít know. Rang gendan 60 quid for red lead and yellow adapter which I have already somewhere!!!
Can anyone tell me if they have had a lead and yellow adapter from eBay that works out the box with out alteration, ill happily buy a cheap set just so mine conform to Sodís law and turn up just after buying new thanks.
Moimo is offline Reply With Quote Quote
Old 09-11-2018   #2
Belgium
Re: Help needed MES leads
I guess you mean the OBDII reader ? You can trust the ELM327 specified "Fiat OK" that's on the net, they're just a version WITHOUT the termination resistor installed, or you can buy any CABLE one (not the little tiny blue sh...) and remove that resistor yourself. The color adapters only swap two wires so the adapter reads the proprietary OBD signal (like Body Computer), you could also do that yourself with a dual inverter and a few pieces of wire/connectors/welding/insulation, which won't get lost in garage stripping, but will be when you sell the car...
BRs, Bernie
Old 10-11-2018   #3
Thanks I see loads are advertised for use with MES, so Iíll get a set of those very Annoying!!! when you own some already.
Old 17-11-2018   #4
Got some off eBay you can see the item and seller in the first two pics, Iíve read loads of stuff about connection interfaces for MES but the best bit of advice Iíve seen is the connection settings in the last picture.Click image for larger version
ID:	195414Click image for larger version
ID:	195415Click image for larger version
Or maybe itís just me that didnít know that
Old 17-11-2018   #5
Moderator
g8rpi's Avatar
g8rpi has donated!
Glad you got a wotkig set.
Note that while the drivers you show work for that interface, they may not for identical looking interfaces from other sellers. The drivers are for the USB to serial interface chip. The ones linked are for the FTDI chip. Ther are at least two other types that can be used in ELM OBDII adaptors and the FTDI drivers won't work for them. You can't tell what chip is used just by design of the adaptor. Always use the drivers recommended by the supplier. There is another issue with counterfit FTDI chips that may not work, or even be disabled by the latest FTDI drivers.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Thread Tools
Wiring RCA leads and Remote leads Head unit Punto mk2 2004 Dalecool92 Newbie Central 0 24-06-2016 22:16
(T) P1135 - what to look for on MES KRaikkonenNo1 Punto (Mk2/2b) 11 24-07-2014 18:23
(T) Arbath mes help dazza73 Stilo 7 23-07-2014 20:08
(T) How to make a Panda OBDII adapter for MES without extra leads. captainslarty Panda 0 20-03-2014 20:54
(T) fiat MES oldhammer Punto (Mk2/2b) 21 17-01-2014 14:35
