General All Three RHS Indicators Not Working!
Optikal
Hi guys,
So I have a very odd issue develop and I can't a solution anywhere!
All three RHS indicators (front, back & side repeater) are not working either on Hazards or on stalk. The left side are fine and all other electrics and lights are fine. The bulbs are fine too.I can't find any confirmation on if there is a fuse or a relay relating exclusively to the RHS or where to even begin to attempt a fix otherwise.
Can anyone help?
Hi mate, thanks for the reply. You mean the Hazards button on the dash? Can you give me a bit more information please because with Hazards on the left side all flash fine, but not the right side, same result on the stalk too.
Yes,hazard button on the dash. Lots of cars need the hazard switch to be in good order,if not it may affect the left or right indicator operation.
I really doubt the hazard swith (H090) is involved: it is a simple NO swith with and internal LED, nor is the stalk one (H005).
Since all RHS indicators are on different outputs and none is working, I'd suspect the body computer (M001) to be the culprit …
BRs, Bernie
Edit: can't upload picture for the moment (site issue ??), will post the drawing when feature is back ...
Thanks Ben, here's the drawing …
BRs, Bernie
  • Like
Reactions: ben
