Previously my climate control used to work but the fan speed was all over the place and often stuck on minimum regardless of what I set it to.
More recently, however, it doesn't work at all for either heating for cooling, even if it's set to maximum. I was looking at a post (called air con/heat just stopped working - unable to link to it), and tried phil0254's suggestion in that post, but nothing happened after 10 minutes - no radiator fan spin.
Note that I don't know where the heat pipes are for the aircon, so I couldn't check if they were heating/cooling.
Does anyone have any suggestions of what could be wrong/any further diagnostics I could do?
Thanks,
Hamish
Thanks,
Hamish
