sussexmechanic
- Oct 16, 2018
- 4
- 1
Hello! Im a mechanic and am hoping for some wisdom regarding puzzling stalling on the following vehicle:
Fiat grande Punto 1.4 8 valve, 2006, Marelli 5SF3.M2 control system
Symptoms: Stalling when warm / hot at idle, difficult re start and repeated stalling - no fault codes.
Checking data the only possible issue is lean condition - worse at low rpm / idle - but zero vacuum leaks.
So far the following have been replaced:
Crank sensor (twice, and phonic learn ok)
Throttle body
Coil pack and leads
ECU (and clocks, body module, engine bay fuse box, key, etc)
Engine wiring loom
Temperature sensor
Disconnecting either Crank sensor or Temperature sensor will allow the engine to run without stalling but obviously not able to drive normally like that.
The O2 sensors are switching ok and swapping pre and post cat sensors makes no difference.
I never like 'firing the parts canon at the problem' but was able to source the above cheaply and after previous bad ECU intermittent fault on previous Marelli system thought best next step but sadly no.
Unplugging / capping off the following makes no change: IAT, MAP, cam sensor, VVT, knock sensor, servo hose, (other than EML on)
All earths & power feeds good.
Im using Snap on & EOBD, some data seems iffy (ignition timing does not seem to correlate to observed using strobe light?) The following listed in data:
Injection control module: programmed
Universal code: not received
Key status: off (with KOEO??)
engine status: parking
Motorised throttle (recovery): not active
Accel pedal (recovery) : 16
PLEASE help
Throttle body
Coil pack and leads
Engine wiring loom
Temperature sensor
PLEASE help
