Hi guys,
Been scouring the forum looking for answers but haven't been able to find something similar.
Here's a run down of the problem and what I have tried so far.
Wife has a 07 Grande Punto 1.4 8v, she complained that it was having intermittent starting issues, found the battery positive was a touch loose, tightened it up nothing more for a while, then one day she complained again and then it was stone dead. I tried it, there was nothing obviously wrong to me besides a possible flat battery issue, because a relay would just bounce and go nuts, but no cranking at all. Tried it again later, it started, but after that I just had the relay go mad.
So, got a new battery, popped that in and still the same problem of the relay just bouncing, thought it might be the key, so got the spare key out and that didn't make a difference. Checked battery terminals tight, the earth under the airbox and swapped the relay with one next to it, same outcome, turn key to crank, no starter just a relay bouncing all the time.
Has anyone experienced anything like this? Are there other things that I need to be checking also?
