Technical Gr.Punto.199. 1.3 Multijet.2006. Startet nicht!
Lezli46
Hello Fiat Selespeed specis!
Gr.Punto. Does not start! 1.3mulitijet.2006 .199. with Selespeed transmission.
Battery., Starter Motor., Ground Cable etc Ok !!!
That happens .., If ignition on:
Faulty display: 'ASR off', 'ESP and HillHolder' is not available, starter motor can not be controlled ,when I start vill. Hidraulikpumpe goes ever with a break of 10-15 seconds., About 10 mp long .., even if ignition off!
To Gear ECU no connection possible with diagnostic equipment, for example., with MES 4.2 .., to other ECU-s but ther are all connection!
Error code: U1711-87 .., no connection Between engine ECU and transmission ECU !!!
I'd verify the connection(s) to and from both ECUs … See diagramms for further details.
Might also help to force a proxy alignement, since motor and dualogic controllers are talking thru CAN ...
BRs, Bernie
