Hello,
Have an 06 1.2 Grande Punto. Issue I have is a the check engine light coming on, code is 0115. From reading other posts I am thinking coolant sensor which if I have understood correctly just screws into the thermostat housing which although difficult to get to should not be too hard.
It is intermittent and seems to only come on when starting after the car has sat overnight. There are no other issues with starting and the engine runs fine and the temperature gauge doesn't show hot. Is changing the sensor the the best first step? Thanks Graham
