- Jan 13, 2018
- 160
- 54
Stuck at work.
Does anyone with access to e learn or drawings know the outside diameter of the 1.2L 8v exhaust pipe.
I got a new centre pipe and chopped the exhaust. Slit both pipes and shoved together.
I'm having trouble getting a gas tight seal and getting the back box aligned to stop any rattling as the joint is too tight.
I'm going to buy a coupler like the one below instead, but I need an outside diameter to buy the right one.
[ame="https://www.amazon.co.uk/Exhaust-Connector-Adapter-Coupler-40mmx44-5mm-90mm/dp/B0735WJJ31/ref=sr_1_1?s=automotive&ie=UTF8&qid=1537173540&sr=1-1&keywords=exhaust+pipe+connector"]Exhaust Pipe Connector Steel Tube Clamp with Screws Adapter Sleeve Joint Coupler (40mmx44.5mm-90mm): Amazon.co.uk: Car & Motorbike@@AMEPARAM@@https://images-na.ssl-images-amazon.com/images/I/41MXTM7uveL.@@AMEPARAM@@41MXTM7uveL[/ame]
Thanks as always,
Thomas
Thanks as always,
Thomas
