chrisalberino
- Jan 12, 2016
- 6
- 3
I am considering replacing one of these on a 2006 Grande Punto. I have seen a video on an earlier Punto model where it appears to be necessary to remove the stereo speaker in order to reach up and remove the check strap from within the door. Can someone please advise whether this needs to be done on the Grande Punto or is it possible just to undo the screws/nuts and remove it directly? If I need to remove the speaker, etc, I will probably try to live with the existing one and noise. Btw, will this eventually die anyway? (just the noise at the moment). Also, could I replace it with one from the back door? (i.e are they all the same?) Many thanks.
