- Aug 16, 2018
- 14
- 7
My Grande Punto 2008 1,2 gear box looked like this:
I thought that drive shaft seal was leaking but I was advised it probably was a gear shift seal leak. It actually was the case and it looked like this:
I ordered a new seal from eBay (30 €). Replacing an old seal took about three hours work and it were pretty simple job. Only tools needed were 10 mm spanner, 13 mm socket, two flat screw drivers, a punch, a hammer and sealant glue.
Take battery terminals off (10 mm spanner).
Remove battery (13 mm socket),
Remove the battery tray (13 mm socket):
Remove clutch slave cylinder (13 mm socket):
Open ground gable nut (13 mm socket) and remove reverse light switch connector:
Gear cables can be removed with one or two screwdrivers:
Gear shifter is attached with five screws (13 mm socket):
Gear shifter removed:
Remove lock pin with a punch:
Remove a seeger ring with a screw driver:
Gear shifter disassembled:
Remove old seal carefully with a screw driver and tap a new seal in place:
Assembly in reverse order. Use sealant when attaching gear shifter to gear box:
Renew gear oil.
Hope somebody find this instruction useful.
Renew gear oil.
