Thread Tools
Old 11-08-2018   #1
Punto 1.4 8v 2006 intermittent starting problem plz help
Will take a lot to fire then when warm will not fire at all will bump... new crank sensor ne plugs new starter motor new bat new map sensor new coil pack help plz
Dannyb152 is offline Reply With Quote Quote
Old 12-08-2018   #2
Belgium
Re: Punto 1.4 8v 2006 intermittent starting problem plz help
Hi Danny and welcome on board !
- have you got any chance to scan the ECU for possible error(s) ?
- You mentionned crank sensor, how about the timing one ?
- Is the temp Indicator showing correct values ?
- Is the car running ok once started ?
First would be to spend some pounds on MES and a ELM327 reader, it will help solving your issue and the potential future ones …
BRs, Bernie
Old 12-08-2018   #3
Right I was not aware of the timing sensor I'll look into that next.... only fault that comes up is crank position sensor ... could you tel me where about the timing sensor is.....
When it fires up it dose run a bit crap like it's missing
Old 12-08-2018   #4
Belgium
Then it's probably the culprit, the Bottom sensor you already replaced will compute the TDC by detecting when all 4 pistons are in mid travel, while the timing sensor will detect WHICH cylinder is in its compression stroke (thus injection & ignition)
Here are some stuff to help locate it … We're looking for K047 and #13
BRs, Bernie
Name:	Engine wiring 1.4 8V.JPG
ID:	193151   Click image for larger version
Name:	Engine fueling 1.4 8V.JPG
Name:	Engine fueling components 1.4 8V.JPG
Old 12-08-2018   #5
Thanks I will buy one and fit it are they also called camshaft position sensor??
Old 12-08-2018   #6
Belgium
Yep !
Old 13-08-2018   #7
Ok iv bought one bosch I'll let you know how it goes thanks again ....
Old 13-08-2018   #8
Belgium
Ok, remember to perform the Learning procedure with the new sensor(s) …
BRs, Bernie
Old 15-08-2018   #9
I dissconected the batt for one hour fired it and it fired on second crank .... a lot better but this morning it took ages to start....... the crank pos Sen is not Bosch I got it from euro car parts could this be a cheap **** one causing the problem ..... thanks again
Old 15-08-2018   #10
nikrox has donated!
Did you perform 'the learning procedure'?...I ask even though I dont know what it is...
nikrox is offline Reply With Quote Quote
Old 15-08-2018   #11
Belgium
Sounds like some improvement no ?
What is your level about checking electrical devices such as sensors ?
When replacing the RPM/TDC sensor (crankshaft) you HAVE TO run the learning procedure (see alttached) !
BRs, Bernie
Name:	RPM sensor 1.2.JPG
Old 19-08-2018   #12
Ok I'll try that thanks
Old 19-08-2018   #13
That's is only part of what I have to do what is the full learning procedure
Old 11-09-2018   #14
This problem is still here.... do you need to code the crankshaft position sensor to the car.... can some one tel me how to do the relearn procedure
Old 11-09-2018   #15
DGPunto has donated!
Always worth getting a copy of MES (https://www.multiecuscan.net/) and an decent OBD2 cable to check codes and engine running information
DGPunto is offline Reply With Quote Quote
Thread Tools
Punto (Mk2/2b) Starting problem Punto Active 1.2 2006 44,000 Miles. Cli1950 Newbie Central 5 20-05-2018 17:46
(T) Intermittent starting problem StuDav Punto (Mk2/2b) 4 01-11-2013 02:23
(T) Intermittent starting problem FIAT PUNTO 1.2 sueonmull Punto (Mk2/2b) 5 17-03-2013 15:21
(T) Punto Mk2 - Intermittent starting Problem nickdd Punto (Mk2/2b) 1 24-11-2009 23:26
Mk2 Punto - Intermittent Starting Problem nickdd Newbie Central 0 24-11-2009 12:17
