Will take a lot to fire then when warm will not fire at all will bump... new crank sensor ne plugs new starter motor new bat new map sensor new coil pack help plz
- have you got any chance to scan the ECU for possible error(s) ?
- You mentionned crank sensor, how about the timing one ?
- Is the temp Indicator showing correct values ?
- Is the car running ok once started ?
First would be to spend some pounds on MES and a ELM327 reader, it will help solving your issue and the potential future ones …
BRs, Bernie
Right I was not aware of the timing sensor I'll look into that next.... only fault that comes up is crank position sensor ... could you tel me where about the timing sensor is.....
When it fires up it dose run a bit crap like it's missing
Then it's probably the culprit, the Bottom sensor you already replaced will compute the TDC by detecting when all 4 pistons are in mid travel, while the timing sensor will detect WHICH cylinder is in its compression stroke (thus injection & ignition)
Here are some stuff to help locate it … We're looking for K047 and #13
BRs, Bernie
I dissconected the batt for one hour fired it and it fired on second crank .... a lot better but this morning it took ages to start....... the crank pos Sen is not Bosch I got it from euro car parts could this be a cheap **** one causing the problem ..... thanks again
Sounds like some improvement no ?
What is your level about checking electrical devices such as sensors ?
When replacing the RPM/TDC sensor (crankshaft) you HAVE TO run the learning procedure (see alttached) !
BRs, Bernie
It's says crank position sensor so if got one but if been told it has to be coded to the car or do the ((relearn procedure)) anyone how do i do relearn!!!
