Thread Tools
Old 14-09-2018   #16
It's says crank position sensor so if got one but if been told it has to be coded to the car or do the ((relearn procedure)) anyone how do i do relearn!!!
Dannyb152 is offline Reply With Quote Quote
Old 14-09-2018   #17
Belgium
Re: Punto 1.4 8v 2006 intermittent starting problem plz help
In post #11 they say " start the engine with temp > 20C and let iddle 10sec " I'm not aware of another learning procedure ...
BRs, Bernie
edit: they're a little bit more talkative in 1.4 8V sction of e-learn, you should NOT press the Accelerator !!
Name:	Cam sensor 1.4_8V.JPG
Old 17-09-2018   #18
Ok thanks
Thread Tools
Punto (Mk2/2b) Starting problem Punto Active 1.2 2006 44,000 Miles. Cli1950 Newbie Central 5 20-05-2018 16:46
(T) Intermittent starting problem StuDav Punto (Mk2/2b) 4 01-11-2013 01:23
(T) Intermittent starting problem FIAT PUNTO 1.2 sueonmull Punto (Mk2/2b) 5 17-03-2013 14:21
(T) Punto Mk2 - Intermittent starting Problem nickdd Punto (Mk2/2b) 1 24-11-2009 22:26
Mk2 Punto - Intermittent Starting Problem nickdd Newbie Central 0 24-11-2009 11:17
