wartangler
- Jun 18, 2018
- 2
- 1
Just giving some experience of a fix to my car.
Engine would turn over once and then die. Diagnostic showed P0105 and P0110 error. I replaced the MAP SENSOR with one off eBay (with 5 year guarantee!) . Still would crank once then die.
I checked earth with continuity tester, replaced crankshaft sensor (Just in case) all connectors disconnected, cleaned, replaced - still same error.
Removing the MAP SENSOR would allow me to start the engine every time but had engine management light showing.
Decided to bite the bullet and buy a new MAP sensor , costing £50, engine started first time!!!
I cleared the ecu error codes, all now good.
Lesson... don't buy a cheap sensor!
Hope this helps someone with the same issue. You're welcome.
