I have a question for your all. I have a Fiat Grande Punto 1.4 tjet from 2007 and it is eating 1L oil ever 1000km.
I guess I don't have a leak cause I have seen big blue clouds of smoke a couple of times and no oil on the ground after standing still for a while.
Question, Is it most common that it is that oil header (it might be called valve stem) that is done for or the piston rings?
I have seen a big blue cloud behind my car when driving normal and then have to slow down to because someone needs to turn and then when I look i the back mirror, a big blue cloud of smoke.. Ones, this also happen when I was at a traffic light before I should take off. As soon as I press the speeder the smoke disappear I have only noticed it ones or twice in every 1000km.
My friend have noticed a few times when we are on the highway and I gear down and give full speed that a little black cloud comes out but not all the time.
Also. do you need to remove the cylinder head to be able to repair oil headers (valve stem)?
The Turbo was change under a year ago and some says it could be the turbocharger seal that is causing this?
Hope this made any sense and sorry for my bad English.
Please ask if you need more information
