Hope it's OK to double-post this here, as no response where I did it before.
Does anyone currently have a PuntoGrande (early) 1368 engine with the top off? I need to measure the vertical depth from deck down to the deepest point of the valve clearance cutouts in the piston tops, at TDC.
Close to Exeter wd be ideal, so I cd come see.
Or else wd anyone take that measurement for me - only to nearest 0.2mm or so. I cd get a https://www.machinemart.co.uk/p/et12...th-protractor/ delivered to you - not micrometer-accurate but does the job.
Reason - fitting a Mk1 Punto head to 1368 block, failed once, now need to re-check measurements before doing it properly this time.
