Thread Tools
Old 11-06-2018   #1
brake warning lights
Hi folks
I got in the car today after 4 days of no use and as I drove away, the handbrake light and abs light came on at the same time. All the brakes seem to be fine and the handbrake works fine. Anybody experienced this before? Tia. Arfurski.
Arfurski is offline Reply With Quote Quote
Old 12-06-2018   #2
Trader Rating: 1
portland_bill has donated!
Re: brake warning lights
After four days, a weak battery may well be low on power. If so, all sorts of warnings will pop up, quite likely not relevant to the actual problem. If you have a voltmeter, check battery voltage, before you start the car, while cranking if possible, and once engine running. Then again immediately after turning the engine off, and again half an hour later.
Note the readings and report. That'll help identify if battery is good, or near the end of its life.
Also remove the left rear lamp and check the connector. They have a habit of getting hot, especially the earth connection, and this causes strange signals from the ECU.
All sorts of strange warning s may occur, causing panic, but the causes are usually simple and cheap to fix.
Likes Arfurski liked this post
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 12-06-2018   #3
Greece
Check brake fluid level first.
cmosfxx is offline Reply With Quote Quote
Old 12-06-2018   #4
Belgium
Quote Originally Posted by Arfurski View Post
Hi folks
... as I drove away, the handbrake light and abs light came on at the same time. All the brakes seem to be fine ...
so they did not pop-up immediately ? Any other info on the display (depend of the trim level) ?
I've had that exactly same thing when power cable to the ABS controler had broken (worn against a metal edge) Strip, solder, insulate, protect and all went fine again :-D
Blown fuse would do the same I guess ...
BRs, Bernie
Name:	ABS Wiring.JPG
ID:	191601   Click image for larger version
Name:	ABS Function.JPG
Old 24-10-2018   #5
Quote Originally Posted by Bernievarian View Post
BRs, Bernie
Thing is bud, when im sitting on a fairly steepish hill the lights dont come on when i start the car but as soon as i drive away, the lights come on. If im parked flat, the lights are on the second i turn the ignition on. Topped up the fluid and it still does it. Odd.
Old 25-10-2018   #6
Belgium
I would still suspect the brake fluid level sensor … How is it doing when down-hill ? It (the sensor) is a simple switch, try to jump it (the wires) to rule-out the sensor …
BRs, Bernie
Likes llamallama liked this post
Old 25-10-2018   #7
I would still suspect the brake fluid level sensor How is it doing when down-hill ? It (the sensor) is a simple switch, try to jump it (the wires) to rule-out the sensor
BRs, Bernie
The light stays on if i go up or down a hill. If im parked on a hill then turn the car on, the lights are off until i drive away. Was thinking it was an abs sensor but cant justify buying all 4 just now. Is the fluid sensor an easy fix? Tia.
Old 26-10-2018   #8
Trader Rating: 1
The 'handbrake' light is a secondary function. It is a brake failure warning light, often just for fluid level. It doubles as the handbrake light to test it every time the handbrake is used. This ensures it is functioning when necessary.
A faulty handbrake light switch can cause problems, but will not usually illuminate any additional lights.
Fluid level low will usually only trigger the one light.
As the ABS light is on, this points at an ABS fault, two lights on may be a function of the warning, to ensure it gets the driver's attention.
If you've checked the fluid level, and the handbrake switch, you can also visually check the wiring from each wheel sensor. These are in vulnerable locations and can be damaged by road debris, twigs, plastic bags, etc.
If visual checks don't locate anything obvious, before replacing anything, the system needs to be read by either the dealer diagnostic machine, or better, MultiECUscan (MES) (Lots of threads on here about this wonderful piece of software). A system read will probably pinpoint the location of whatever sensor or component the ECU is unhappy with. A standard code reader will not read ABS codes, as the diagnostic standard is for powertrain only.
If you update your profile with your location, there may be someone nearby with MES willing to help.
Panda Alessi
Old 01-11-2018   #9
Quote Originally Posted by portland_bill View Post
perfect thank you for the response. Ill get the local garage to scan it for me. Location updated. thanks again.
Old 02-11-2018   #10
Trader Rating: 1
If it is a Fiat dealer or Fiat specialist, or someone with Fiat specific software, you will get meaningful results from a scan. If they are just using generic scanner software, the codes may not tell us what we need.
Likes Bernievarian liked this post
Panda Alessi
Old 08-11-2018   #11
Portugal
worn braking pads ?!?
ntrindade is offline Reply With Quote Quote
Thread Tools
(T) Low level brake lights failed and dim warning lights on dash biguglycar Croma 6 27-06-2015 16:54
(G) Brake warning lights on janmolby Marea 6 15-12-2006 10:52
(G) Brake warning lights on janmolby Marea 0 04-12-2006 14:33
(G) Brake warning lights on janmolby Marea 0 04-12-2006 14:32
(T) Brake warning lights ging18_1999 Tipo (Classic) 3 19-04-2004 22:42
