Old 25-04-2018   #1
Check engine P0171
Hello guys,
I am a new driver and new to messing around under the bonnet. I have done a few things to my Fiat Grande Punto, 1.4 56 plate. Including replacing the rear breaks, front suspension, and exhaust. More than anything I am enjoying taking it to pieces and putting it back together. However I have come a little unstuck with the latest problem.
The check engine light came on and is reporting the error P0171 (Running Lean in Bank 1). I checked for leaks and could see / hear any. A friend told me it was one of the 02 sensors on the cat so I have replaced the pair.
Recently I have replaced the MAP sensor and disconnect the battery for an hour. When I start the car the check engine light is still on and it now stalls while driving. E.G driving a 35 in 4th gear and the engine stalls.
Staring to think I have bit off a little more than I can chew.
If anyone could offer a little insight I would be really grateful.
Kind regards,
Chros
cjones108 is offline Reply With Quote Quote
Old 26-04-2018   #2
Belgium
Re: Check engine P0171
Hi Chris,
How was the P0171 after you replaced the lambda sensors ?
How was the MIL ?
Why have you replaced the MAP ?
Is it a genuine part ?
What are the revs @ 35 in 4th gear ?
Any particular condition for the engine to stall ?
BRs, Bernie
(T) Check Engine light, ESP & Hill Hold Not Available, Lumpy Engine. :( jrwilshire2003 500 7 08-09-2016 11:25
(T) error codes P1221 P0171 no use of throttle? Sir16v Stilo 1 05-05-2016 22:55
(T) Stilo 1.6 P0171 running lean. coolman61 Stilo 9 21-02-2012 11:17
(T) P0138 and P0171 Crossfordkid Grande Punto 1 30-09-2010 16:07
