Thread Tools
Old 05-03-2018   #1
Australia
Question Dualogic automatic mode will not engage
I have a 2007 FIAT 1.4L Petrol with a automatic duallogic gearbox in Melbourne, Australia.
This gearbox has been very annoying for a while now. One day two weeks ago it just wouldn't engage the automatic mode after I turned the car on so I called FIAT and made an appointment for them to look at it.
Then a week later, it resolved itself and the automatic mode would work again but this week it stopped working again.
Car drives fine in manual mode with no obvious issues that I can see. It is just extremely annoying driving a sequential manual. There are no warning lights or anything that I can see anywhere. As far as I can tell the car drives fine but just won't engage the automatic mode.
Has anyone experienced this similar issue? Was it successfully resolved? What was the resolution?
I am very reluctant to deal with FIAT without having a little more info hence posting here. I hear they are notoriously expensive to fix, i guess given the rarity. I bought this second hand for cheap and not too keen on spending a fortune.
tkha007 is offline Reply With Quote Quote
Old 05-03-2018   #2
Belgium
Re: Dualogic automatic mode will not engage
Hi ... Who ?
since you say it's not engaging in Auto Mode but works ok in Manual, I would suspect the Hall-effect sensors in the gear/mode selector ...
BRs, Bernie
Old 09-08-2018   #3
Malaysia
mine, 11yo car. no auto mode
all totally manual whether shift up or down, need to do manually. if left at gear 4 when slowing down, it won't auto**** diwn. the car will jerking and eventually dies. had to shift down manually.
ahhl is offline Reply With Quote Quote
Old 09-08-2018   #4
Belgium
There is a 4 bits message sent from the selector lever to the dualogic controller that reports the levers's position. The signal is elaborated thru a diode matrix out from 7 Hall-effect sensors. There is a true table that can be used to measure if the correct bit is sent for every lever position.
I already sent this table ans schematics to other posters, do a search on Dualogic and you'll find the threads…
BRs, Bernie
Old 09-08-2018   #5
Belgium
There is a 4 bits message sent from the selector lever to the dualogic controller that reports the lever's position. The signal is elaborated thru a diode matrix out from 7 Hall-effect sensors. There is a true table that can be used to measure if the correct bit is sent for every lever position.
I already sent this table and schematics to other posters, do a search on Dualogic and you'll find the threads…
BRs, Bernie
Old 10-08-2018   #6
Malaysia
Quote Originally Posted by Bernievarian View Post
BRs, Bernie
thanks Bernievarian
is this repairable DIY? have you DIY it, change the hall sensor or the diode?
Old 10-08-2018   #7
Belgium
Hi Ahhl,
unfortunately I haven't done it myself and I Don't even know if one can open the shell to explore the inner parts, BTW probably not available from Fiat (st)dealers. The method given in the manuals is there to tell if the issue comes from the lever or not …
Have sent you a PM about your Italian manual…
BRs, Bernie
Old 15-08-2018   #8
Malaysia
few days ago, the car suddenly can only engaged odd gears. no error on the display. nothing but can only engaged odd gears.
no other choice, i get myself to friendly frequented fiat workshop.
he also puzzled but he didn't think its the sensors problem as if its is the sensor problem, the display should have show an error.
anyway he hookup to MES and the error shows as pump leaking, pump tank empty error. but no such thing happened. oil still there.
after a while he performed a reset to the selespeed end of line procedure. the pump initially hesitant to engage 2,4 gears but the after awhile it managed to reset the gear.
he believe its the pump/actuator issue that might need to be replaced. anyway that actuator was a second hand one 4 years ago. i think i might need to replace to a brand new one as might not able to get second hand one anymore.
free of charge, told to tried it first
Old 15-08-2018   #9
Belgium
Seems one valve isn't working properly and the selector stays only in 'odd gears' position.
More likely not related to a pump issue; personnaly I would remove it from the box and open it to check what's wrong, it's not rocket science and you Don't even need any special tooling, beside E-sockets (maybe) …
Good luck tho, BRs, Bernie
Thread Tools
How to turn off the automatic (rain sensor) wiper mode. arvydok Tech Talk 1 31-01-2018 14:21
(T) Dualogic Automatic Mode Won't Engage rotu Grande Punto 13 06-12-2017 09:01
(T) Dualogic Gearbox - Manual Mode Unavailable james92056 Grande Punto 2 22-01-2016 05:22
(T) Dualogic gearbox - driving in manual mode cattard 500 4 19-07-2015 09:47
(T) twinair dualogic update:gear changes issue on eco mode CptBill 500 2 02-03-2013 20:43
