Thread Tools
Old 23-02-2018   #1
Boost Regulator Vacuum Hose
Hey all,
Been having an engine issue. Think I've pinpointed it to this...
I don't need to replace the whole unit - does anyone know where I can pick up a new vacuum?
Thanks!
Aiming for 'one of' the cleanest + most stylish Red GP T-jets
NickFontana14 is offline Reply With Quote Quote
Old 23-02-2018   #2
Romania
Re: Boost Regulator Vacuum Hose
That is not a vacuum hose. it only sees boost. I say this because at that diameter pretty much any hose can cope with the small 1.3-2 bar boost.
You need to measure the diameter then Ebay => xmm silicone vacum/boost hose.
OR:
Just cut off 2 cm of the hose you have, then stick it back on; reuse the clamp. takes 2 minutes. OEM quality!
Zip-tie the boost controller solenoid to something. This is probably the reason why the hose split.
aurick86 is offline Reply With Quote Quote
Old 23-02-2018   #3
Quote Originally Posted by aurick86 View Post
OR:
Thanks for that! I've got 3mm washer tubing that I use for my boost gauge at home...
Will this be okay?
It doesn't move too much, I think it's just happened over time.
The car over boosts at about 22psi...
Old 24-02-2018   #4
Belgium
Remove from turbo, cut bad part, reinstall, jubilee-clip (no tie-rap: too weak) and you're done. And definitely attach the valve somehow !
BRs, Bernie
Old 12-05-2019   #5
everson38 has donated!
Quote Originally Posted by NickFontana14 View Post
Attachment 188655
Will this be okay?
Hey matey. Did you find the correct hose in the end. Having same issue and think I want to replace hose fully?
everson38 is offline Reply With Quote Quote
Old 13-05-2019   #6
Trader Rating: 1
portland_bill has donated!
Likes everson38 liked this post
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 15-05-2019   #7
Australia
Attachment 188655
Will this be okay?
I came across this type of tube you have, that someone previously installed,
I wouldn't recommend this,
Like mine before replacing, the tube gets too hot and soft, so when pulling a vacuum, the tube would collapse/squeeze,go get some 4mm high heat resistant tube, should only be a few bucks from your local hardware store,
I'll get a photo if you would like
llamallama is offline Reply With Quote Quote
Old 15-05-2019   #8
Australia
Oh 4mm being the wall thickness,
Also yeah I have noticed my GP gets up to 22psi then drops if you wanna try keep pushing it,
Old 16-05-2019   #9
Quote Originally Posted by llamallama View Post
I would appreciate a picture mate.
Old 16-05-2019   #10
Australia
Something like this
Old 16-05-2019   #11
Something like this
Thanks mate. Appreciate you doing this and sending me the message. Appreciate it
Old 16-05-2019   #12
Australia
No worries
Thread Tools
(T) Vacuum Hose JAM113 Punto (Mk2/2b) 25 29-03-2010 22:03
(T) Today I was bored so I repared vacuum advance regulator :) Uno driver Uno 3 28-06-2008 15:24
(T) boost regulator vacuum pausan_ro Marea 0 19-12-2005 12:56
(T) Vacuum Hose? jamie86 Cinquecento / Seicento 10 22-11-2005 14:36
Vacuum hose. Morty Mort Lets Talk FIAT 13 04-05-2004 17:26
