Technical Boost Regulator Vacuum Hose
East Sussex
Hey all,
Been having an engine issue. Think I've pinpointed it to this...
I don't need to replace the whole unit - does anyone know where I can pick up a new vacuum?
Thanks!
That is not a vacuum hose. it only sees boost. I say this because at that diameter pretty much any hose can cope with the small 1.3-2 bar boost.
You need to measure the diameter then Ebay => xmm silicone vacum/boost hose.
OR:
Just cut off 2 cm of the hose you have, then stick it back on; reuse the clamp. takes 2 minutes. OEM quality!
Zip-tie the boost controller solenoid to something. This is probably the reason why the hose split.
OR:
Thanks for that! I've got 3mm washer tubing that I use for my boost gauge at home...
Will this be okay?
It doesn't move too much, I think it's just happened over time.
The car over boosts at about 22psi...
Remove from turbo, cut bad part, reinstall, jubilee-clip (no tie-rap: too weak) and you're done. And definitely attach the valve somehow !
BRs, Bernie
Will this be okay?
I came across this type of tube you have, that someone previously installed,
I wouldn't recommend this,
Like mine before replacing, the tube gets too hot and soft, so when pulling a vacuum, the tube would collapse/squeeze,go get some 4mm high heat resistant tube, should only be a few bucks from your local hardware store,
I'll get a photo if you would like
Oh 4mm being the wall thickness,
Also yeah I have noticed my GP gets up to 22psi then drops if you wanna try keep pushing it,
I would appreciate a picture mate.
Something like this
