Old 13-12-2017   #1
Boost leak
Hi all,
Had this car a week and a half and already there's a million things that need doing that weren't mentioned or noticed in the test drive..
I think I've got a boost leak somewhere - car seems to go fine sometimes then other times just loose boost and is slow as... Seems to be intermittent. I think it's been mapped by someone else and wondering if it's mapped for v power/supreme (if people do that) as it's only since putting lower octane fuel that I've notice it.
Its either that or my ramair filter, but it's been boosting fine with that on at first.
Is this a common problem?
GP S1 on 99k miles.
Aiming for 'one of' the cleanest + most stylish Red GP T-jets
NickFontana14 is offline Reply With Quote Quote
Old 14-12-2017   #2
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Boost leak
Quote Originally Posted by NickFontana14 View Post
Hi all,
GP S1 on 99k miles.
What engine?
If it's new to you, been mapped/modified previously and you've modified the intake I think you are pretty much on your own. Too many variables. You will have to check and rule out all the possibilities one at a time. Good diagnostics such as a registered copy of Multiecuscan is a good pace to start.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 14-12-2017   #3
Re: Boost leak
Quote Originally Posted by g8rpi View Post
What engine?
Robert G8RPI.
It's a Tjet.
Looks that way, just trying to see if there are any common issues. If boost solenoids or recirc valves have a tendancy to go then I can get this sorted if it's a common issue.
Nick
Old 14-12-2017   #4
Romania
Re: Boost leak
If we are talking about the t-jet:
if it's not been mapped right it will go in limp mode when it gets to a certain boost pressure.. THERE WON'T BE A ERROR (not initially).
But it will limit boost by opening the bypass valve or by closing the throttle plate.
Boost should be
It could also be a cracked hose in the wastegate/boost solenoid area.
You need somebody with MES that knows what they're doing to log+graph different parameters.. intake pressure, throttle position, boost pressure before the intake, wastegate solenoid....and a few others...
For the trained eye it will be pretty easy to spot a problem.
aurick86 is offline Reply With Quote Quote
Old 15-12-2017   #5
Re: Boost leak
Quote Originally Posted by aurick86 View Post
Boost should be
It's booked in for a health check and rolling road (to check for power dips etc) on January 9th. Should I avoid boost or just keep on going?
(T) Fixed Boost leak,,,no power? dmacdou1 Bravo 6 04-09-2019 11:13
(G) Ahhhhhhh Boost Leak BLUNTY Coupe 6 05-01-2011 20:22
(T) Turbo boost leak Benzsc1 Grande Punto 3 27-09-2010 19:09
(T) Boost leak alexGS Uno 3 10-01-2007 12:39
(T) Boost leak!!! aghhhh Dunc Uno Turbo Uno 4 04-04-2005 10:11
