Hi all,
Had a nightmare last night..
Was driving along having an issue where the driver's side windscreen wiper teeth appear to have broken - the wiper after a few wipes will actually wipe off the end of the car - so I most definitely need a new wiper set.. Grr. It's the first time driving in the rain since buying the car, so who knows.
Then all of a sudden, ABS, ESP, HH and ASR all stop working. No apparent reason, just driving a long at about 50mph. I'm hoping it's not going to be a common problem as it's only thrown this error up when the car has been wet/driven in rain- it's never happened before and I've only had the car a week today.
It appears to be an intermittent fault as when the engine is restarted it takes a couple of minutes for me to lose ABS / Traction Control again.
I'm going to check to see if the ABS Module is wet, and see what fault codes I can find to see if I can track down what the issue is. Looking at the forums though, it's a common problem. Does anyone have any solutions/suggestions?
Thanks,
N
Thanks,
N
