Were they this clean and shiny when you found them? Or have you cleaned them up?
They appear to have curved outer faces, which suggests they might be the bearing faces from the inner driveshaft joint. In which case there should be three, not that you can re-use them.
Check the driveshafts where they enter the gearbox. Likely you have one gaiter split and a floppy shaft. New inner joint needed.
Looking at
ePER, it appears that the spider bearing is one part, and the outer joint separate. You might get away with just the spider, but if they were clean when you picked them up, likely there's a lot of wear in there. If they've been running without grease for any time, the whole joint is best replaced.
Spider bearing, item 3 in first pic. Also need new gaiter and clips, and ideally new circlip.
Outer joint, item 8 in second pic. There's a circlip on the inner end of its shaft to hold it into the gearbox, but I can't find that listed.
I've just grabbed the parts listing for a 1.2 8v Grande, but even that shows a choice of Delphi or GKN shaft, with different part numbers for the joint, so care is needed.
But no circlip shown.
Don't just buy those bits though, they may not be the right ones for your vehicle. To determine actual part numbers for your car would need to know full VIN and model, engine and year.
