Technical Fiat Punto 1.2-Engine light -yellow on dashboard
sprabu
Hi All,
I am newbie from Leamington Spa. I have bought Fiat Punto 1.2 (2007 model) from one of the private seller last week Thursday. It was running good when I test drive before buying it. After I took after 2 days when I was going in highway it got 'Check Engine' light on, After that it did not go back. Car drives good no differences, only after 50mph it takes more time to reach 60 or 70mph. I need to press more gas to reach that. I am not sure whether it is in limp home mode or no?
I tried calling old owner, they did not pick the phone and got message that I am the new owner I need to take care of this now.
Can you please help me if similar issues did you get or any suggestions?
Regards,
Sprabu
Hi All,
Regards,
Sprabu
Hi. Cam timing after a cam belt change.
Common issue..needs plugging into ECU to correctly align the inputs of the 2 x
Timing sensors
Takes around 15 minutes.
How much cost it takes around? Do I need to go to any specialised garage?
Regards,
Saravana
Timing sensors
If it's from a cam belt change then you don't need to have it plugged into a diagnostic. Search "Phoenic Learn" on the forum her for the reset process
Hi All,
Thanks for all your responses, I just plugged ELM OBD Bluetooth device tonight to check what is the error. it came up with below fault code.
P0136 O2 Sensor Circuit Low Voltage
Can some body explain how to clear this error? Is it ok to drive with this error?
If I drive with this error will it spoil the engine or associated components?
Regards,
Saravana
Any suggestions on this post please?
Hi All,
Regards,
Saravana
