SikWitIt123
- Nov 5, 2017
- 24
- 6
Hi all,
I have had a fair few issues with my Grande Punto since I got it just over 2 years ago. However, the most recent one is have me scratching my head. I have very little mechanical knowledge but I will try and explain in as much detail as possible.
Car: Fiat Grande Punto Sporting 2007 1.4 16V (95HP)
First symptom: Car did not start, litterally nothing happened when I turned the key. The battery is fine, so that could not have caused the car not to start.
Fast forward one week and I am home from holidays and try to start the car again and it started this time. Now it had been very windy and wet previous to the car not starting at all prior to the holiday. So I took the car up to my mechanic, who got me a new starting motor (as mine was on the way out, made a screetching noise everytime I turned the ignition). However, he said that the car started fine everytime they tried it so he could not see any other apparent problem.
After the starting motor was fixed, I took the car to work and it was fine for a day. The next day, I noticed that the car jerked a bit in the first few minutes of driving and then on the motorway it was mostly fine. On the way home from work, the jerking continued and when I pulled up to our estate, I felt that almost all power was gone in the car and when I pressed the gas pedal nothing happened. The car was stil running so it did not stall but litterally just did not have any kind of response when I pressed the gas.
What could cause the car to loose all power but still run? Previously, I had an issue with a coil pack which was faulty and had somewhat similar symptoms but not as severe as not getting any rev at all.
I havent tried to drive the car since and will contact a mechanic tomorrow, but I am curious if someone has experienced the same problem.
Could a faulty alternator be the culprit or could the ECU be faulty.
I have some error messages coming up when I start the car but they have been there a while before this problem started. It is the ASR/ESP/Hill Holder ones, which when I read other threads seem to be caused by other things, not relating to the car having any power.
I would appreciate any input, as I am curious on what can cause this.
Johan
Johan
