Technical Automatic gearing troubles
Jonasson22
My Punto is from 2013 and ive had this problem in the last 2 years. Whenever the engine is cold and im driving it suddenly goes from lets say fourth gear till neutral and the beeping sound comes and i have to turn off the engine and start it up again. Really annoying and also dangeeous. Dunno what i should do. Ive had it in for service and theyve switched the gearing oil snd so but the problem still arrives. Its most commen in the winther but also happens in the summer if i block the brakes.What is wrong with the car?? Ive seen that some fiat 500 has the same problem but there isnt a solution. Hope you can Help.
Best regards from Denmark
Just discovered that the start&stop function doesnt work and dont Know for how long it hasnt, could it be the reason?
