Fannythefiat
- Feb 5, 2016
- 10
- 4
Used to have a seicento but my girlfriends just bought an 07 1.2 grande punto and is having a couple of issues.
Firstly, the clutch biting point is on the floor. Clutch doesnt engage when the pedal is fully down however it engages as soon as the pedal is lifted (this isnt really an issue but seems odd to me).
Secondly, it's pretty difficult to get into gear more often than not, it varies between all the gears, there isnt any crunching just a resistance through the gear stick. It does cruch into reverse but usually engages fine every time (only gear that does). Tbh I think evey car ive driven crunches into reverse lol
Done a little research and tested the clutch, tried to pull away in third and the car stalls, revs dont rise. When the clutch is engaged to drop down a gear the revs act as they should which apparently suggests the issue isnt the clutch?
Brake fluid levels are fine (apparently the clutch and brakes share?) Pumping the clutch seems to make no difference in making gear selection easier.
Going to get it down to a garage on Monday, just wanting an idea if possible
Also read that its a hydraulic self adjusting clutch that cant be manually adjusted? Could the system just need bleeding? I'm guessing its likely the issues are connected.
She said that on the test drive it went into gear fine, however the car had been sat a while and went to have a new downpipe fitted before we picked it up. Gear selection issues seem to have worsened but the clutch feels the same as it was, weve had it 3 days and used 25 quid of fuel.
Think thats about everything I can add :')
Thanks in advance
Thanks in advance
