Old 15-09-2017   #1
everson38 has donated!
Auxiliary Belt tensioner replacement.
Hey guys have a grande Punto tjet 1.4 2009.
Just wondering if anyone has any info on how to change the tensioner?
Got a few.pics of.my setup. Any help would be great thanks again .
Attached photos from top and underneath angles.
ID:	184380Click image for larger version
ID:	184382Click image for larger version
everson38 is offline Reply With Quote Quote
Old 16-10-2020   #2
Re: Auxiliary Belt tensioner replacement.
You may want to give these a read / watch:
http://4cardata.info/elearn/199/2/19...0001/199000607
https://www.youtube.com/watch?v=6Z0C...PghmR&index=15 - This is in italian and its for a timing belt change, but you see how they refit the drive belt. If you youtube search timing belt changes for grande punto's and fiat puntos , as removing the aux belt is part of the process you may get a better understanding of removing tensioner.
https://www.youtube.com/watch?v=Xv_4tKhoOQ0 - My video explaining some things. Apologies for length wasnt sure if u need auxbelt and tensioner removal explanation.
Hope it helps. If you need more help i just remembered I still have my older tensioner so can do a video of how it works out the car, but currently just going into work so will have to be tomorrow now.
Likes oldmanhouse liked this post
Old 16-10-2020   #3
Quote Originally Posted by everson38 View Post
thanks @everson38, i managed to get my aux belt tensioner removed in the end! as i mentioned in my DM, i couldn't get a hex bit and socket in there but i went and bought some hex keys and that did the trick with a 'cheater bar' on the end.
had some trouble with one of the lower engine mount bolts too but got there in the end.
now onto replacing the timing belt!
Likes everson38 liked this post
oldmanhouse is offline Reply With Quote Quote
Old 17-10-2020   #4
Glad you got it sortedmate, so is all this becuase you plan on changing your timing belt?
(T) Auxiliary Belt Tensioner Fitting Help multieddie Multipla 13 05-02-2018 23:29
(T) Auxiliary belt replacement - alternator. Dezbo Ducato 7 28-05-2017 23:39
(T) Lower Pulley Tensioner Replacement / Aux Belt Tension BrianMcL Croma 20 22-11-2015 17:50
(T) Multijet Auxiliary Drive Belt Replacement Shuggie Panda 4 27-07-2014 14:57
(T) Auxiliary belt tensioner/pulleys AM55 Ducato 2 07-04-2013 19:53
