So i was going along the motorway with a fair amount of weight in the boot, and as i came off the power there was a horrific shuddering noise while coasting in gear, which disappeared when i pressed the accelerator again. The shuddering got worse and worse until i got to the end of the motorway and had to come to a stop. As i was braking, I came out of 6th gear, went to select a lower gear and i couldnt find one as the selector positions seemed to have moved, i eventually found what i thought was 3rd, slid it in and after a big clunk, no power. Pulled over, got the car up on a recovery truck and the rear gearbox mount has failed, leaving the gearbox resting on the support beam, and the passenger side driveshaft tore itself off at the knuckle (the knuckle is still in the gearbox keeping all the oil in, but the rest of the driveshaft is dangling down from the wheel). It's clear i need a new gearbox mount and driveshafts, but is it likely that something within my gearbox is destroyed or should i be okay repairing just those parts?
Any response is greatly recieved, if anyone has experienced anything like this before would love some info before i go to a "gearbox specialist" who try to charge me far too much.
Ben
Ben
