Thread Tools
Old 17-06-2018   #16
everson38 has donated!
Re: What's is name of this part - Part of front shock assembly
Quote Originally Posted by Ben D View Post
NOOOOO!!!!
They are standard ones, 10mm lift and softer!
Mine are Kilen Sport. As with all performance springs that stiffen and or lower they only come in sets of four. If I was buying again, I'd get Eibach, Kilen Sport are a bit on the stiff side. As I said originally, two choices...... A pair of OE from Fiat at about 180 or a set of four Eibach for 120 ish if you do some searching. You've got a nice car with low miles, don't bodge it for the sake of a few quid.
Lmao I can picture how you screamed out that noooo lol. I'm a noob with parts buying sometimes I thought they were the sports ones. I think these are the correct ones? Click image for larger version
everson38 is offline Reply With Quote Quote
Old 17-06-2018   #17
Ben D has donated!
Those are the Sportlines. Big drop and stiff. You want the Eibach pro kit, will only drop about 15-20 mm and not such a harsh ride.
Ben
Likes everson38 liked this post
06 Grande Punto 1.4 8v daily and T-Jet toy
Ben D is offline Reply With Quote Quote
Old 17-06-2018   #18
Ben
Thanks again Ben. Believe I have found the right ones as seem to be only ones on ebay. Also PS called fiat to enquire to how much for 2 new front springs: 219.00!!! So even though I'm not a fan of lowering cars it's just too much so will give these a try Click image for larger version
Old 17-06-2018   #19
Ben D has donated!
Yup, they're the ones. If your top mounts are not new I'd change them at the same time as they are fairly cheap and have to come off anyway.
Your fiat dealer is even more expensive than Arnold Clark!
Old 18-06-2018   #20
Lol your telling me lol. Yeah I was planning on changing top mounts. Did you change your top mounts and if so did you go with some from ebay or buy from say euro car parts or OEM?
Old 18-06-2018   #21
Greece
Quote Originally Posted by everson38 View Post
Don't get them from ebay,
here you go
http://www.fiat-sportiva.de/Tuning-S...Set::1829.html
cmosfxx is offline Reply With Quote Quote
Old 18-06-2018   #22
Quote Originally Posted by cmosfxx View Post
here you go
Thanks for this mate. Have you ever used them before I'm always a bit hesitant about using companies never used before / abroad opposed to UK?
Old 18-06-2018   #23
Greece
Yes they are ok got for it
Thanks everson38 thanked for this post
Old 12-07-2018   #24
Have to say for anyone who is skeptical they should not be. A great company I spoke with them on fb messenger and they were great. When I placed my order I left a note saying can they cpfirm on fb for me that they received order and they did and then arrived about 2 days of paying so instead of 152 paid about 130. Very polite would use again.
Old 12-07-2018   #25
Hey Ben just dropping you a thanks for the help with my shocks and all the info I have attached a picture of them below and plan to install next week. Just for yourself I used a website someone else suggested called Sportiva squadra in Italy and they are very good and came quick if your ever go for parts. The rear springs seem to have this plastic tubing on them do you know if they are supposed to be installed with them on?Click image for larger version
Old 14-07-2018   #26
Ben D has donated!
The plastic is to stop noise other coils contact each other. Is that the pro kit? Thought pro kit springs were black?.
Ben
Old 21-09-2018   #27
Ben
Thanks Ben. They should plastic be orientated a specific way I. E top or bottom. Well I think they are my invoice says they pro kit. but I'm gna message eibach and the company squadra sportiva again and see what they say. Also whilst I have you. I am thinking about changing my top strut mounts. Seen some on ebay and both say are compatible but one is 10.00 but looks more premium due to metal fixings, would you say it's worth while the upgrade? 29.99 to 39.99
Thanks any advice appreciated Click image for larger version
ID:	194327Click image for larger version
ID:	194328Click image for larger version
Old 21-09-2018   #28
Ben D has donated!
Pretty sure the fronts only fit properly one way up. They won't seat the other way. My mounts are all plastic, been ok so far, think they were Febi or may have been genuine. Can't remember which went on which car but never buy the cheapest you can find.
Ben
Old 21-09-2018   #29
Ben
Cheers mate. Yeah I've seen a couple genuine parts and also looked at that febi brand u mentioned. Do you buy your parts like febi, eibach via ebay or do u go straight to the company say on their own website
Old 08-10-2018   #30
That part on the top under the rusty looking nut is this
http://www.vauxhallsuperstore.co.uk/.../Stop_55701796
Not seen it from aftermarket Fiat supplier and genuine they are about 15 each. You may not need it be the rubber on both my cars was starting to perish..
Ben
Hey Ben mate
Was wondering if you knew where you can get securing nuts for shock suspension. I.e the top mounts securing nut and also the securing nut that holds the suspension to engine bay that you can see when you lift bonnet up? (See pic). Looking to buy all fiddly parts as I know my luck will result in breakage or rounding lolClick image for larger version
Thread Tools
(T) Mk1 Rear shock part number goodgirl156 Panda (Classic) 14 04-12-2013 17:05
Rear Shock Part Number Required Andy FIAT Boo Archives 5 21-11-2007 00:21
(G) part # shock absorber bolts dnLcal Bravo / Brava 5 16-06-2007 21:51
FAO anyone with part cd. Air flow meter part no. needed Ashley h FIAT Boo Archives 7 27-04-2006 19:34
